3550EUR for Nissan 200sx s13 with 1UZ-FE Lexus engine
roliss
Postitus Postitas roliss »
Selling my nissan 200sx with V8(1UZ-FE)
The engine came from Lexus LS400.
Tha car ir located in Latvia,but it can be driven to Estonia with no problems.
If someone is interested - please write private message.
SPEC-LIST:
Exterior:
Has been sprayed matt-black colour
Lightened body interior, the chassis is in good condition, has been repaired
Stock suspension
Battery relocated to boot
New brake lines
17" BK-Racing wheels
Ultra wheel bolts
Custom toned JDM-style taillights
Front Xenon 6000k lights
Interior:
25mm steering wheel hub
Nismo shiftknob
B&M shortshifter
Interior ceiling in black colour
Stereo system with speakers in front
Engine&Driveshaft
Custom-made engine mounts with polyurethane bushes.
1UZFE 4.0Liter V8 engine from low mileage Lexus LS400
Castrol 10w60 racing oil
Gearbox nissan sr20det, with welded bellhousing from 1uz-fe
Shifter sits in original position
Castrol 80w90 gearbox oil
Standart nissan 200sx prop-shaft
Welded rear differential
Custom made aluminium lightweight flywheel, made specially in machining-shop
SPEC ceramic racing clutch
SPEC ceramic racing cover
Custom clutch slave cylinder location
Custom made pilot bushing
Original exhaust manifolds rewelded to fit in S13 chasis
2x60mm to 1x3" straight exhaust pipes, with custom made exhaust silencer backbox
Removed EGR from engine, air-con and thermo-fan also is removed-custom
shorter drivebelt.
Removed un-necessary vacuum hoses.
New timing belt fitted with new pulleys.
Original s13 radiator with custom electric fan on button.
Custom made 3" polished cold air intake.
3" free flow air-filter
Custom-made and rerouted powersteering lines.
The engine is running on stock 1uz-fe ECU, but needs a new engine management.
New walbro 255LPH fuel pump and new fuel filter and rubber fuel lines.
Want something like this?
http://youtu.be/Rix63ANXAN0" onclick="window.open(this.href);return false;
Viimati muutis roliss, 11.07.2012 18:53, muudetud 5 korda kokku.
wilson
Re: For sale Nissan s13 4.0L V8 Lexus 1uz-fe
Postitus Postitas wilson »
price ?
roliss
Re: V8 s13 for sale 4000eur!!!!
Need to sell this car FAST, price 4000eur!
roliss
3550EUR!!!
roliss
Re: 3550EUR for Nissan 200sx s13 with 1UZ-FE Lexus engine
