M:200sx S13 coilover vedrustus
Renn
Postitus Postitas Renn »
Tootja:Kei-Office
Spring rate: 9kg/mm front, 7kg/mm rear
Upper mounts: pillowball
Hind: 750 €
Kontakt: 53 452 241 Rene
Kei Office is owned by Keiichi Tsuchiya, D1 judge, revered as the grandfather of drift. Damping is adjustable to 4 presets as well as height adjust without upsetting spring preload (top end feature).The first thing to otice is how much more robust the base of the Kei Office coilover is, with a larger diameter. Secondly and more importantly is the locking ring at the base of the strut, allowing ride height to be changed independant of spring compression. On the Tein unit the spring must be compressed to shorten height, and is limiting factor in raising the car will then be keeping the spring captive. The Kei Office coilover has none of these problems. The Kei Office item also has damping adjustment which the Tein does not. These are all things to look out for when buying coilovers.
Viimati muutis Renn, 06.02.2011 20:05, muudetud 1 kord kokku.
MXS-PoWeR
Re: M:200sx S13 coilover vedrustus
Postitus Postitas MXS-PoWeR »
ummm kasutatud ikka kallis :| :?
Golf 3 GT TDI 66KW Crazy RaT= http://foorum.vwklubi.ee/viewtopic.php?f=50&t=95606 , Nissan S13 Project + tuning soon coming
Renn
tänapäeval ei saa isegi peksa tasuta, rahakott võidakse ka ära võtta...
teemakohased kommentaarid teretulnud ...
Rene
Renn
hinnamuudatus!
