Uus turbo sai tellitud, pole veel kätte sanud.
Aga T25 turboga tegemist:)
T25 DIRECT BOLT ON REPLACE STOCK T25 TURBO
SIZE: 2.0" INLET,2.0'' OUTLET
COMPRESSOR:42 AR; EXDUCER: 59.7MM;INDUCER: 37.8MM
TURBINE : 86AR; EXDUCER: 52.9MM; INDUCER: 45.47MM
TURBO MANIFOLD FLANGE: T25 FLANGE; DOWNPIPE FLANGE: 240SX 5 BOLTS FLANGE
TYPE OF COOLING: OIL AND WATER COOLED
TYPE OF BEARING: WET FLOAT BEARING
SET AT 8 PSI AND CAN MAX UP TO 27 PSI,SPOOL TIME AT 2500RPM,MAX UP TO 300HP
sellised on andmed antud turbo kohta, mis plaanis peale panna...
