M: Garret TA0302
enta
M: Garret TA0302
Postitus Postitas enta »
tech data:
Make : GARRETT AIRESEARCH
Type : TA0302
Speed: Up to 100,000 RPM
Intake pressure: 0,6 bar - from 2,000 rpm engine speed
at full load, limited by a wastegate
which diverts exhaust gasses.
Lubrication : Under pressure from
the engine's lubrication circuit.
Turbine wheel : Steel
Turbine housing : Cast iron
Compressor Wheel : Light alloy
Compressor Housing: Light alloy
Center housing : Cast iron
Bearings : Smooth bronze bushings
ristilötk umbes 1mm.
56254787
enta
Viimati muutis enta, 27.07.2010 0:17, muudetud 1 kord kokku.
enta
enta
