O: väline wastegate Audi vm. auto oma
Postitatud: 29.05.2005 13:34
Postitas Ragnar
Vaja siis välist wastegate'i !
Postitatud: 30.05.2005 13:11
Postitas Red
nagu alati - olemas
Astu läbi ja võta - Greddy S type
Recommended for under 400hp use
GReddy Blow Off Valves are easily adjustable to prevent both premature boost leakage and compressor surge. Each is made of durable cast and billet aluminum frame and the valve to diaphragm ratio provides performance that cheap piston types cannot offer. The spring stiffness adjustment screw and the two different sizes give the GReddy user the option to match vehicles with mild upgrades to heavily tuned engines. Also available in easy to install kit form for many turbocharged vehicles.
Kena päeva puhul saan sulle teha hind: 3000.- EEK
Postitatud: 30.05.2005 14:43
Postitas Ragnar
noh kõik turbomehed, ehitajad... kellegil kodus ei vedele üleliigset wg'd ?
Postitatud: 30.05.2005 14:56
Postitas Kuuno
Red kirjutas:nagu alati - olemas
se on blow off aga ragz tahab Wastegatet!
Postitatud: 30.05.2005 15:09
Postitas Red
oi sh*t - õige ju...mjah, see on aint tellimuste peal...
