O: väline wastegate Audi vm. auto oma
Vaja siis välist wastegate'i !
Viimati muutis Ragnar, 30.05.2005 17:42, muudetud 1 kord kokku.
nagu alati - olemas
Astu läbi ja võta - Greddy S type
Recommended for under 400hp use
GReddy Blow Off Valves are easily adjustable to prevent both premature boost leakage and compressor surge. Each is made of durable cast and billet aluminum frame and the valve to diaphragm ratio provides performance that cheap piston types cannot offer. The spring stiffness adjustment screw and the two different sizes give the GReddy user the option to match vehicles with mild upgrades to heavily tuned engines. Also available in easy to install kit form for many turbocharged vehicles.
Kena päeva puhul saan sulle teha hind: 3000.- EEK
JS Power - Filmi 6, Tallinn
Performance & Tuning Car Parts
se on blow off aga ragz tahab Wastegatet!Red kirjutas:nagu alati - olemasAstu läbi ja võta - Greddy S type
