M:340L/H kütuse pump
Renn
Postitus Postitas Renn »
Hind 75€
Kontakt 53452241
1 x Genuine KEMSO 340 Fuel Pump
(For gasoline vehicles, In-tank design, E85 Compatible)
• 2 x Gradient density Fuel strainers, with Lock ring
(Two strainers included to cover all models)
• 1 x 8*280mm flex hose
• 1 x Rubber hose
• 1 x Wiring connector
• 2 x Crimp connectors
• 2 x Hose clamps
• 1 x Rubber base
• 2 x Zip-ties
Specifications:
Flow: 340 Liter per Hour, at 43psi, 13.5V
Operational Pressure: 43-90psi
Pump Body Diameter: 3.8cm
Overall Length: 12cm :badgrin:
Renn
Re: M:340L/H kütuse pump
Müüdud
