Wts: lexus sc400, 1uz, ecu, turbo
Postitatud: 12.12.2018 12:25
Postitas zumbrr
Wts: Lexus sc400, 93 big rod engine, manual, torsen lsd- 4200€
1uz swap- big rod- 700€
Korvet ecu- 350€
550cc 2jz injectors-150€
Ct26 toyota int/wg turbo 0.48ar best for 2.0 engines (0.7bar-370hp 2jz) swap for bigger
T4-1 turbo new, ar.68- up to 800hp- 180€
2jz parted out- crank, cams, pumps, block- full engine
Re: Wts: lexus sc400, 1uz, ecu, turbo
Postitatud: 12.12.2018 12:27
Postitas zumbrr
Rb25de gearbox with short shifter-180€
Postitatud: 31.01.2019 20:44
Postitas Rixlaur
Tere kas 550cc pihustid kõrgeoomilised ?
Postitatud: 31.01.2019 20:48
Postitas Rixlaur
Pilte turbost ?
