Wts: lexus sc400, 1uz, ecu, turbo
zumbrr
Postitus Postitas zumbrr »
Wts: Lexus sc400, 93 big rod engine, manual, torsen lsd- 4200€
1uz swap- big rod- 700€
Korvet ecu- 350€
550cc 2jz injectors-150€
Ct26 toyota int/wg turbo 0.48ar best for 2.0 engines (0.7bar-370hp 2jz) swap for bigger
T4-1 turbo new, ar.68- up to 800hp- 180€
2jz parted out- crank, cams, pumps, block- full engine
Viimati muutis zumbrr, 12.12.2018 12:29, muudetud 1 kord kokku.
zumbrr
Re: Wts: lexus sc400, 1uz, ecu, turbo
Rb25de gearbox with short shifter-180€
Rixlaur
Postitus Postitas Rixlaur »
Tere kas 550cc pihustid kõrgeoomilised ?
Rixlaur
Pilte turbost ?
