Müügiks pakkuda Haltech Platinum Sport 2000. Juhtaju tuleb maha Audi AAN-ilt koos mootori juhtmestikuga ning koos ühe (1) EGT anduri ja selle plokiga.
Hind: 1100€
Hetkel võimalus proovida ,et kõik toimib nii nagu peab!
Vajadusel aitme paigalduse ja seadistusega!
U2U
Sten@sleepers.ee või kristjan@sleepers.ee
Tel: 53963713 või 53450189
Tallin
Features:
•11 additional user-definable auxillary inputs
•Up to 13 additional user-definable auxillary outputs (Depending on configuration)
•Fully user-definable 32 x 32 mapping ( Up to 1024 points)
•Wideband “Auto tuning” using user definable target AFR table
•Narrow and Wideband closed loop O2 control
•Staged injection control for multiple injectors per cylinder (inc rotary)
•3D mapped rotary engine ignition split
•Soft and hard cut rev limiter
•EGT fuel correction
•Tuning via TPS with manifold pressure correction
•Dual map switching for fuel/ign/boost
• Anti-lag (Rally and Launch style)
•Rotational idle
•Launch Control
•VTEC cam timing control
•VANOS cam control (intake cam only)
•True variable cam control supporting late model Toyota’s, WRX’s and EVO’s
•Dual intake runner control
•Onboard 2.5 BAR MAP sensor (or use with external MAP up to 10 BAR)
•Custom sensor calibration (Use your own sensors for temps or fuel/oil pressure etc)
•Open or closed loop boost control ( Road speed, RPM or gear based mapping)
•Closed loop idle control (Stepper motor and BAC type)
•Extra injector control
•Thermo-fan control ( Duty cycle or on/off )
•Intercooler fan/spray
•Alternator control (Mazda)
•Engine control relay function
•Nitrous switching with fuel / ignition correction
•Staged shift lights
•Aux fuel pump control
•Tacho output (5v,8v,12v)
•Turbo timer
•Torque converter lock up
•Air con request idle up
•Windows compatible software
•”In the field” updatable Firmware provides all the new features as soon as they are available
•Onboard and laptop data logging with Data Viewer software
•USB communication with laptop/PC
•CAN Bus port for direct plug in communication with Racepak and Aim Dash system.
M: Haltech Sport 2000 Juhtmestik tehtud Audi 2,2 turbole.
- Kontakt:
https://www.facebook.com/sleepersgarage/" onclick="window.open(this.href);return false;
https://www.instagram.com/sleepers.ee/" onclick="window.open(this.href);return false;
http://www.sleepers.ee" onclick="window.open(this.href);return false;
http://www.fcp-engineering.com/" onclick="window.open(this.href);return false;
