1400 eur (sis KM)
eight injection drives
• eight ignition outputs
• ten analog inputs
• four temperature inputs
• ten digital inputs
• eight auxiliary outputs
• two, thirty four pin, waterproof connectors
• e-throttle (external device)
• external, 2.5 bar or 5 bar, MAP sensor (sold separately)
• Up to 6D fuel and ignition mapping
• Precision closed loop cam control (four cam, independent control)
• Digital triggering, all OEM patterns
• OEM idle hardware supported
• Up to 8 channel sequential fuel and ignition
• Large number configurable input and output channels
• Rotary - up to four rotors, fully sequentially staged injection and sequential ignition
• 8 peak and hold individually configurable injection drives (referenced to gear,speed or throttle position etc)
• 6D boost control with three switchable tables
• Motorsport features - antilag, launch control, flat shift
• Continuous barometric correction (on board)
• CAN port
• QuickTune - automated fuel tuning
• Individual fuel, cylinder & ignition correction
• Odd-fire engines & two-strokes
• USB tuning cable included
• Stats recording into on-board memory
• Gear compensations for spark, boost etc
• Real time selectable dual fuel, ignition and boost maps
• Sync and crank sensors can be a combination of Hall effect, variable reluctance or optical
• 4Mb internal logging memory
• Staged injection
• Closed loop knock control
• Electronic throttle control via external module
available separately (see photo above)
• 8 auxiliary outputs
• 8 analog inputs
• Firmware updates via linkecu.com
