M: UUED 8 x 850cc kõrge oomised EV1 style pihustid
altz
Postitus Postitas altz »
Müüa siis 8x 850cc pihustid. Kõrgeoomised ja uued, pole kasutatud.
Spec:
Coil Resistance: 12 Ohms / High Impedance
Static Flow Rate: 80 lb/hr at 43.5PSI ( 300kPa )
Gain: 0.12ms/MG
Offset: 0.055ms
Turn on time 1.14ms at 14VDC
Turn off time: 0.85ms at 600KPa
Voltage: 8-15 Volts, nominal 13.5 Volts
Amperage: 1.0 Amps
Pressure: Min 30PSIG/ Max 100PSIG
Variance:3%
Overall Length: 2 7/8 inches, 74 mm
O-ring to O-ring Length: 2 1/2 inches, 63 mm
Diameter: 16 mm
Orings: Top and bottom, 14.5 mm
Design: Bosch GEN III EV1 Style Fuel Injector
O-Rings Included: Yes, preinstalled
Injector Design: Metal & composite plastic
Orifice Type: 1 hole
Connector Type: Bosch EV1
Filter Design: Basket filter design at inlet
Fuel Delivery: Single Nozzle Cone Shape
Spray Pattern: 15 Degree Spray Cone
Komplekti hind 350.-
Asub Tallinnas,
kontakt: 5231000 või PS
altz
Re: M: UUED 8 x 850cc kõrge oomised EV1 style pihustid
Müüdud.
