M: Borg Warner EFR6758 and more
pinka
Postitus Postitas pinka »
Hi have up for sale:
Borg Warner EFR 6758 turbo slightly used 0.64 a/r hot side T25 flange Vband 3' exhaust: SOLD
Custom made stainless top mount exhaust colector with T25 flange wrapped in heat wrap: SOLD
Exedy Stage 2 Ceramic paddle clutch kit: 280 EUR
JGY Lightweight flywheel 7kg: 150 EUR
Brian Crower adjustable sprockets for SR20 (brand new): 180 EUR
Parts located in Riga, Latvia if any questions please contact me by PM or +37126187663 Janis
Can speak RUS/ENG
Viimati muutis pinka, 09.12.2015 21:21, muudetud 1 kord kokku.
pinka
Re: M: Borg Warner EFR6758 and more
Updated price on the turbo, the turbo itself has covered less than 1000 km!
kilplane
Postitus Postitas kilplane »
see on üks väärt turbo!
olen näinud, kuidas Borg Warner EFR 6258 töötab ja kui aus olla teeb meele päris kadedaks.
turbo käib ringi veel mitu minutit peale mootori seiskamist.
Edu müügiga.
pinka
kilplane kirjutas:see on üks väärt turbo!
Edu müügiga.
Aitäh
pinka
Bump.
X-mas coming it should look great under Christmas tree.
Price can be discussed.
Motary1
Postitus Postitas Motary1 »
as an owner of that 6258 Kilplane mentioned, I really recommend this turbo for epic response and smooth power delivery with high output - best of all worlds :-D
Good luck with sale!
pinka
Turbo and manifold sold, added clutch kit and flywheel
