Tere,
Jäi üle:
Coated Aluminium Tube
Hardline Tube
The incorporation of the PA 12 coating and 1AlMn 1 Aluminium Tube have created a new automotive standard.
The advantages include:
1. Type F offers hand manipulation without the need of a Tube Bender.
2. High resistance to wear, abrasion, corrosion and impact damage.
3. Weight saving over conventional tube and hose.
4. The PA 12 coating has excellent adhesion to the tube. The coating will not chip, peel or flake.
5. Excellent Bend Radius as shown in the data table.
6. Smooth bore for a low friction coefficient.
• Construction:
• Tube - Seamless Drawn Aluminium Tube (AlMn 1) to DIN 1725
• Coating - Polyamide 12 (Pa12)
• Temperature Range: -40°C to +155°C (-40°F to +310°F)
• Couplings: JLS Compression Fittings or AN 37° Flare Fittings
Sisemõõt:8mm
Kogus: 11m
Hind :6 Euri/M
Kontakt: 56 623 102
Tervitades,
Sven
