Kuidas ühendada
vag 1.8t mootorile mis on narrowband ajuga?
innovate lc1 ühendamine?
Re: innovate lc1 ühendamine?
Vaata manuali, lc1 on väljund olemas kus ta simuleerib narrow band signaali aju tarbeks.
6. Optionally, the YELLOW (Analog out 1) and/or BROWN (Analog out 2) can be connected
to the analog inputs of other devices such as data loggers, ECUs, or gauges. If either one or
both of these wires are not being used isolate and tape the wire(s) out of the way. The default
analog outputs are as follows: Analog output one is 1.1V = 14 AFR and .1V = 15 AFR. This is
a simulated narrowband signal. Analog output two is setup as 0V = 7.35 AFR and 5V = 22.39
