TõnuriCCE kirjutas:oled sa muidu surveastet ise reaalselt mõõtnud ka?
Peale seda jama mõõtsin vedelikuga, siis oli surveaste ca 10.5 pean ülesse otsima need arvutused, ehk saab siis keegi üle kontrollida veel.
on the effects of reducing the surface area of the combustion chamber and piston crown, by reducing the surface roughness have shown improvements in torque of 3%, reduction in piston crown temperature of 6°C and increases in the exhaust gas temperature of up to 10°C (providing more exhaust gas energy for the turbocharger).
The testing also revealed that even if the surfaces where covered in combustion deposits the above benefits where still realised, at slightly lower values, due to the lower surface area available for heat transfer by convection. It must be stated that both the chamber and piston crown must be polished to approximately 0.8z surface roughness or an optical irror finish.
Allikas:
http://www.j-body.org/forums/read.php?f ... 86&t=57445 --> Rohkem huvitaski tegelikult need õlipihustid sellel lingil, ei mäleta et oleks olnud neid enda mootoril... Eks kui kodumaale tagasi tulen siis saan üle kontrollida. Aga mille õlipihusteid selle lingi viimastel piltidel kasutatud on ja milliseid on siine rahvas kasutanud?
Well ive worked on both blocks, and the 16v block has a oil pressure reducer fitted to the block FACE on the main gallery so it does not over pressurise the hydraulic lifters, and i also thought with the 16v engine revving more it would help stop most of the oil going to the top of the engine at high RPM because a 16v will rev to around 7000rpm standard and the 8v does 6400rpm standard.
The 8v block does NOT have this reducer, so i would of thought if you use a 8v block with a 16v head it would over pressurise the hydraulics and send most of the oil to the top of the engine at high revs starving the main/big end bearings of oil.
Well you may be able to drill and tap the restrictor into the 8v block as you say but it won`t be easy
Allikas:
http://www.migweb.co.uk/forums/engines- ... about.html --> sellele küsimusele vajan ikka veel vastust, kuna enamus postitusi selle kohta on sealt kustutatud ja kunagi postitatud pildid on ka sealt kadunud. Ühesõnaga tahan teada kus c20xe mootori plokil see " oil pressure reducer " asub ja kuidas seda c20ne plokile paigaldada???
