M:NISSAN S13,S14,300ZX, JDM SILVIA JUPPE
skylinegtt
Postitus Postitas skylinegtt »
Nissan 200SX S13
Doors with window and lifter and door cards – 25Eur;
Side mirror - 12Eur;
Headlight – 18Eur;
Prefacelift drivers seat – 15Eur;
Fenders plastic covers kit – 12Eur;
Engine parts:
CA18DET exhaust cam good condition with CAS tooth – 30Eur;
CA18DET engine block blokas – 30Eur;
CA18DET carter – 15Eur;
CA18DET ignition coils – 10Eur;
CA18DET arternator – 10Eur;
CA18DET intake manifold with injectors 4x 370cc also fits to Honda – 45Eur;
CA18DET Power steering pump – 12Eur;
CA18DET Cooling radiator – 15Eur;
Also have a lot of brake, suspension and other parts.
Nissan 200SX S14/a
S14/a LHD -> RHD steering wheel removal full kit(all needed parts including small details) – 930Eur;
S14a Tail lights kit 3pcs – 130Eur;
S14a Rear trunk with stop light – 30Eur;
S14a Front bumper – 40Eur;
S14a Hood with defect repailable – 90Eur;
S14a turn signal – 25Eur;
S14a Fog lights – 30Eur;
S14a Europien Headlight – 130Eur;
S14a Front brakes kit (calipers, pads, disks) – 75Eur;
S14a Rear brakes kit (calipers, disks) – 35Eur;
S14a Airbag for steering wheel 26Eur;
S14a Manual Gearbox – 280Eur(also have all parts for swap AT->MT);
S14a Air Flow Meter MAF – 30Eur;
S14a Stock wheels with tyres – 100Eur;
S14a Fuel pump – 20Eur;
S14a Automatic Gearbox with hydro coupling – 45Eur;
S14a drive shaft – 15Eur;
S14/a Fenders plastic covers kit – 20Eur;
S14/a 5 lug kit into S13 front/rear – 75Eur;
S14/a Rear sub frame with good bushings – 35Eur;
S14/a Front lower arms – 25Eur (upgrade into S13 because it is 7mm longer then S13, it will increase front camber);
S14/a Front shocks – 25Eur;
S14/a Rear shocks – 30Eur;
S14/a Airbag under dash – 20Eur;
S14/a Rear bumper – 30Eur;
S14/a Full lether interior – 70Eur also fits to S13 and other Nissan models
S14/a Vynil interior – 35Eur;
S14/a Doors with window and lifter – 55Eur;
S14/a Miror – 20Eur;
S14 Europian front Headlights 75Eur;
S14 Grill – 20Eur;
S14 Hood 60Eur;
S14 Fenders 40Eur;
S14 Turn signals 12Eur;
S14 Fog lights Priesrukiniai – 30Eur;
S14 Corner lights – 12Eur;
S14 Front bumper with spliter – 35Eur;
S14 Tail lights 15Eur;
S14 Airbag for steering wheel – 20Eur;
S14 Driveshaft – 15Eur;
S14 Air Flow meter MAF - 35Eur;
JDM SIlvia OEM grill – 30Eur;
JDM Silvia Klimatronic with all sensors and all harness and conectors – 75Eur;
JDM Silvia OEM rear bumper spats – 25Eur;
JDM Silvia OEM folding mirrors – 60Eur;
JDM Silvia OEM rear glass without rear wiper hole – 45Eur;
Engine parts:
SR20DET Alternator – 15Eur;
SR20DET starter – 12Eur;
SR20DET injectors 4x 370cc – 35Eur;
SR20DET coil packs – 25Eur;
SR20DET Thermo coupling – 15Eur;
SR20DE engine block from Silvia S14 RWD perfect condition (could be remade as DET block) – 45Eur;
SR20DET carter 2 parts – 20Eur;
SR20DET Cam Angle Sensor CAS – 25Eur;
SR20DET Power steering pump – 15Eur;
SR20DET Cooling radiator – 45Eur;
SR20DET Cooling panel – 30Eur;
Nissan 300ZX Z32 VG30DETT
Manual gearbox kit for swapping from AT->MT (full kit all needed parts including small details) – 930Eur;
Automatic Gearbox with hydro coupling – 90Eur;
Diff V-LSD 100Eur;
R16 stock wheels staggered setup with tires – 150Eur;
Fuel pump 255Lph for max 700HP+ - 60Eur (performance upgrade for S13, S14/a);
Hood Aluminum – 120Eur;
Headlights – 45Eur;
Headlights with Xenon – 70Eur;
Fender – 45Eur;
Roof window – 35Eur;
Doors – 30Eur
Door window – 30Eur;
Mirrors – 30Eur
Tail lights kit 3pcs – 120Eur;
Rear bumper – 45Eur;
Rear trunk with window and spoiler – 45Eur;
Steering wheels – 25Eur;
Front shocks with springs – 35Eur;
Rear shocks with springs – 45Eur;
Engine’s VG30DETT parts:
Starter – 30Eur
Alternator – 30Eur
Thermo coupling – 25Eur;
Ignition coils – 20Eur;
Injectors 6x 370cc – 60Eur
Cam Angle sensor CAS – 45Eur
Air Flow Meter MAF – 90Eur
Intake manifolds with throttles and TPS – 45Eur
Power steering pump – 30Eur
Almost brand new cooling radiator KOYO – 70Eur;
JUPID ASUVAD LEEDUS. KEL HUVI VÕTKU ÜHENDUST (henri.freiberg@hotmail.com) TOON LEEDUST ISE KOHALE!
skylinegtt
Lähen reedel Leetu, kes tahab midagi siis paluks mulle hiljemalt neljapäeva õhtuks meili peale kirja panna!
n00kie
Postitus Postitas n00kie »
kas on olemas CAS andur ? kui on anna teada 58003005 ... votaks siis koos nukkvolliga ...
skylinegtt
See nädal jääb asi katki kuna tuli midagi vahele. Kes tahab juppe saada siis meili aadress on yo_yos14@yahoo.com
Saate ise tellida. Nii palju võin öelda , et ta on usaldusväärne kuna tellisin suvel temalt mootori ja see jõudis ilusti minuni.
Marx087
Postitus Postitas Marx087 »
Olen isegi S14-le tema käest Vilniusest juppe toomas käinud. Kaup korralik ja ülisoodne, inimene usaldusväärne. Julgen soovitada.
200SX S14
hitman2
kas käid ikka seal leedu vahel
Postitus Postitas hitman2 »
oleks vaja nissan 200sx s14a 97a esi tulesid
Motary1
Postitus Postitas Motary1 »
SR20DETi roolivõimendi kronsat mulle?
skylinegtt
vabandan väga, unustasin teema lukku panna sest ei tegele enam sellega. Kellel huvi võin kontaktid anda ehk saab kuidagi tellida. Kustutage teema ära!!!
skylinegtt
TEEMA LUKKU!!!
