M: Varuosadeks Nissan 200SX S13 SR20DET
Siim
Postitus Postitas Siim »
Hello,
I'm breaking higly modified Nissan 200SX S13 93year with SR20DET
Engine SR20DET from S14:
CL Race Rod Main and Roads bearings
ARP main studs
Sleevered engine block
block surface polished
Eagle Rods
JE Forged Pistons
JE Piston Rings
New OEM Nissan Chain and tension kit
Cometic metal head gasket
ARP Head studs
polished engine head surface
Tomei PONCAMS Cams
Tomei Adjustable Cam gears
Tomei Rocker Arms Stopers
Head Porting
Valves adjusted
Intake manifold porting
Resized Thortle Body
+ gearbox from S14
+ JDM harness from S14 Kouki made to fit for S13
+ Cooling radiator from S14(fits S13 with SR20DET)
Only 2330Eur
76mm custom made exhaust with N1 mufler 175Eur
custom made exhaust manifold top mount 145Eur and downpipe - 45Eur
gt3076R dual ball bearing turbo + stanless steel braided watter cooling and oil feed pipes - 815Eur
Turbonetcs external wastegate and screamer pipe 120Eur
F1 Stage 3 Clutch kit 205Eur
Greedy type RS blow off 60Eur
Z32 maf 90Eur
Apexi Powe Intake Air filter - 60Eur
FPR - 25Eur
Walbro fuel pump - 85Eur
Apexi Power FC with hand controler + boost controller 585Eur
Tomei 2-way clutch type lsd - 570Eur
Apexi el. 60mm gauges black (oil temp, oil pressure, boost) + live unit with recording/peak/warning - 350Eur
Kenwood KDC-M6021 MP3 - 75Eur
Short shifter - 60Eur
Injectors 850cc - 280Eur
FMIC 600x300x76 + piping - 190Eur
Nissan 200SX S13 dark red 93yaer without engine and gearbox - 670Eur.
If u need something let me know.
Info:
tel. +37060459830,
e-mail: yo_yoS14@yahoo.com
RFL
Postitus Postitas RFL »
tundub, et vahendad Andriuse kuulutust?
Siim
RFL kirjutas:tundub, et vahendad Andriuse kuulutust?
jup
