As easy to use as a manual boost controller, but with advanced electronic
boost controller response & consistency, the PRofec Type-S keeps things
simple. Based on the ever-popular Original PRofec B-Spec, the Type-S has
two rotary switches to select two independent boost setting, a “LO” and a
“HI”, while another “GAIN” switch compensates the wastegate’s valve response. Engineered with a matched, quick acting, large capacity inline control solenoid,
the Type-S can increase boost as high as 3.0kg/cm2 (42.66psi) and it works
with both integral and external wastegate set-ups, while still being compatible
with our Remote Switching System or SCC and adapter.
Key Features:
• The PRofec Type-S Boost Controller is as simple to set as a manual boost control and features electronic response.
• PRofec Type-S Boost Controller is based on the original B-spec but features a
higher capacity solenoid valve.
• Increased boost has never been easier to achieve. Simply turn the knob on one of the two factory presets, “LO” or “HI”.
• “GAIN” boost adjustment helps promote wastegate compensation and keep constant boost.
• High volume solenoid valve and press sensor take full advantage of faster wastegate response and consistency.
HIND: 4300.-
Artur 5240837
