Asuvad Tartus. 56921046 või kiri PS.
Hind 200.-
Center to center length: 144mm
Big end diameter: 50.6mm
Small end diameter: 20mm
Big end width: 24.9mm
Small end width: 24.9mm
Type: Forged 4340 aircraft chrome moly quality steel for racing
H-beam Conrods Quantity: 4 Pieces a set
Bolts: Including Genuine ARP 2000 bolts
Bolts Size: ARP 2000 3/8" bolts
Tolerance: Balanced to +/- 1 gram in set
Piston Bolt Hole: +-4/1000mm
Power: 600hp ~ 800PS per set
Strength of the fastening (PSI): 220,000/230,000 PSI Torque: 48ft ≈ 65 NM
Top acceleration: 9000rpm
