M: Goodridge 200 seeria voolik
ML
Postitus Postitas ML »
Üle jäänud 10m 6mm siseläbimõõduga voolikut
200-06
bore size 0.344", 8.73mm
braid od 0.547" , 13.89mm
working pres 69bar , 1000psi
max pres 420bar , 6000psi
weight 0.201km/m , 0,135 lb/ft
min bend radius 2.50mm , 63,5mm
temperature range -46ºC (114.8ºF)MIN , 150ºC (302ºF)MAX
H: 200.-/meeter (soomest tuli ~800.-/m)
Application :
Fuel, Oil, Coolants, Methanol, Water
Material / Construction :
Integral stainless steel reinforced
synthetic rubber with hi-tensile outer
stainless steel braid
Please Note:
Not to be used for fuel use inside
a cockpit.
Goodridge 200 Series hose is the
premier stainless steel braided
nitrile hose. Designed to Goodridge’s
exacting specifications and exclusively
manufactured for Goodridge, this hose
has been supplied to motorsport racing
champions for many years. 200 Hose is
designed for use with a wide range of reusable
aluminium hose ends and provides
essential protection and resistance to
high pressure, temperature, vibration, fire
risks and chafing. It is constructed of a
seamless synthetic CPE inner with an
integral stainless steel braid and a high
tensile stainless steel outer braid.
200 Series hose has the highest
corrosion and fire resistance threshold
of any stainless braided nitrile hose
available. It can be used with all
synthetic lubricants, fuels, oils,
coolants and alcohols including
methanol and nitromethane.
