O:Suprale sidur
Postitatud: 22.08.2007 14:34
Postitas tartuvaim
sooviks kuuelabalist sidurit MK4´le
oodatud on kõik pakkumised
Postitatud: 22.08.2007 19:23
Postitas parm
tere,
CENTERFORCE® DUAL FRICTION DF510150 11724,48eek
Generates up to a 90% increase in holding capacity over stock systems. This centerforce clutch/disc set is designed for use with engines producing high horsepower and torque output, and any radically altered high performance street vehicles. This centerforce clutch system is also ideally suited for use with four wheel drive vehicles. All Centerforce clutch systems provide smooth engagement and light pedal pressure without compromising high performance.
ACT Clutch Kit: TS4-HD00 12115,30eek
Advanced technology clutch kit. Kit comes with heavy duty pressure plate, modified street disc, release bearing, pilot bearing and alignment tool. This clutch offers 588lbs of torque. Not recommended for street use due to harsh engagement.
ACT Clutch Kit: TS4-HDR6 13659,02eek
Kit with 6 puck race disc - 753 lbs TQ capacity 33% increase
SPEC ST933 11580,47eek
torque 755 lbs
komplektis on korv+ketas+survelaager
tarne 2 nädalat
olavi
