M: MaxxECU MINI (Turboclub liikmetele hea hind)
550BHP
Postitus Postitas 550BHP »
MaxxECU MINI
Waterproofed aluminium case
Boost control (triple stage)
Traction control
Internal loggings
Shift-cut and launch
Advanced warning system
Launch control
3 BAR Built-in MAP-sensor
4 injector outputs (high impedance)
4 ignition outputs
4 extra outputs (GPO)
2 extra analog inputs (0-5V)
2 extra digital inputs (HALL)
CAN bus
Target engines for MaxxECU MINI
All 1-4, 6 and 8 cylinder engines
Up to 4 cylinders fully sequentially (using a digital input as HOME)
Up to 8 cylinders in wasted spark
MaxxECU MINI inputs
Intake air temperature sensor (IAT)
Coolant temperature sensor (CLT)
Throttle position sensor (TPS)
1 trigger input (VR/HALL). Automatic trigger level detection
2 digital inputs used for example for speed sensors (Hall) or switches
2 extra 0-5V inputs. Can be used for additional sensors such as for measurement of fuel/oil pressure
Built-in 400kPa MAP-sensor for up to 3bar/43PSI of boost
MaxxECU MINI outputs
4 injectors outputs. High impedance only
4 ignition outputs. 5V signal to drive ignition modules, CDI units or coils
4 outputs for extra features. Can be used to control virtually anything. Fuel pumps, idle control, boost solenoids, nitrous, shift lights, fans, warning lights, etc. GPO 1-3 (2A), GPO 8 (2A)
MaxxECU MINI technical
CAN bus for expansion modules, OEM vehicle CAN, ODBII
USB communication for tuning with MTune
8MB memory for internal logging, up to 1000Hz
Supply voltage 8-22V
ARM Cortex-M3 120MHz main processor
Resolution on ignition: 0.1 degrees
Resolution on injectors: 0.001 ms
Updates the fuel and ignition calculations 2000 times per second
The fastest PC communication on the market
85x120x43mm excluding protruding connectors
Weight: 245g (ECU only)
TURBOCLUB liikmetele hind ainult: 465 +km
Minu kontaktid:
Gert Leisson
info@maxxecu.ee
+372 5837 7713
UNT & LEISSON - Racing & Tuning parts https://www.facebook.com/UNTANDLEISSON
MaxxECU maaletooja http://www.maxxecu.ee
FMIC.EU (Kõik kaubad -12%) http://www.fmic.eu
ATOMIC-SHOP.EU (Kõik kaubad -15%) https://www.atomic-shop.eu
