http://www.auto24.ee/kasutatud/auto.php ... rhash=9e70" onclick="window.open(this.href);return false;
Haruldane S60R, 6k manual, BSR tuning ja custom remap by Crank stage 2 , 265kw/500nm.
3" rv.summuti Simons resonaatoriga.
custom intercooler vahejahuti 2,5" alu.torustikuga, HKS blow off valve, õhuvõtt KN`i kuivkoonus filter.
Veermik: Spec tugevam sidur ja uus survelaager, garantiiga renoveeritud roolivôimendi pump ja roolilatt .
Salong: turbo,-õlirõhu lisanäidikud
18" uueväärsed nael,-suverehvid.
Volvo S60R lisainfo Wikipedia:
Volvo's S60 R used a Haldex all-wheel-drive system, 2004–2005 models came with a 6-speed manual transmission.
Other aspects which set the R apart from standard S60s were the large Brembo front and rear four-piston brakes, blue faced "R" gauges, standard HID headlights, as well as the Four-C suspension system.
Semi-active suspension with Four-C (a short name for "Continuously Controlled Chassis Concept") allows the user to select from three modes: Comfort, Sport, and Advanced. "Comfort" attempts to soften the car over bumps, while "Advanced" firms the suspension considerably and gives more aggressive throttle response - a setting Volvo implies is for use on the race track. This is accomplished through a drive by wire throttle, allowing the same pedal travel to result in different performance when the appropriate mode is selected,electronically controlled shock absorbers that can adjust themselves 500 times a second, and a complex series of sensors throughout the body of the vehicle. Volvo collaborated with high-tech system developer Ohlins Racing AB and shock absorber manufacturer Monroe for the self-adjusting shock absorbers
M:Volvo S60R
M:Volvo S60R
