M:4 x Siemens Deka 80Lb/h pihustid
Postitatud: 07.06.2016 11:57
Riiuli nurgale vedelema jäänud vähekasutatud 4 x Siemens Deka 80Lb/h (830-870cc 3bar) kõrgeoomised pihustid.
spec peaks olema selline:
Flow rate: 3 BAR/43.5 PSI
830 cc/min 80 lbs/hr
9.89 g/sec
Length: 3 inches, 74 mm
Diameter: 19 mm
Orings: Top and bottom, 14.5 mm
Part number available: 110324 - Minitimer/EV1 electrical connector
Coil Resistance: 14 Ohms (high-impedance)
Sample Latency: 0.714 ms at 14 volts
Hinnasoov 160 €
5kolm906860
turbofreakeu@gmail.com
9.89 g/sec
Diameter: 19 mm
Hinnasoov 160 €
5kolm906860
