Features:
*3 digit 7 segment LED (with dots)
*4 digit 7 segment LED (with dots)
*Voltage output. High resolution (up to 5V, 12bit, programmable output curve)
*RS232 level: directly plugs into PC or USB-RS232 adapter or small dongle for CAN-physical layer bus (will not need to be removed from network even for firmware reflash).
*inputs and outputs related to supply and WBO2 and EGT measurement
*free outputs: power and signal level (external referenced voltage output)
*extra inputs: analog input and RPM input
*button
Firmware features
*WBO2. real WBO2 control circuit (full implementation), not a guess from narrowband voltage as most ledbar displays
*EGT (with cold-junction measurement)
*onboard-temp
*dimming
*Data can be logged to PC for further analysis
*firmware upgrade via bootloader
*bootloader upgrade is possible (for improved network support)
*RPM input (VR or HALL, several trigger-types) for logging or display.
EDIT: Soovitan seadme võimalusi võrrelda Innovative'i toodete omadega, näete ise komapktsuse/omaduste/hinna vahet ( http://www.es-tuning.ee/?page=16 ).
Välja näeb selline:
