MÜÜDUD
Postitatud: 21.11.2013 23:10
Postitas Kpt. Trumm
Aeg on edasi liikuda ja selle tulemusena paneks müüki oma keevituse. Algajale ideaalne. Vajab vähe seadistamist ja on lihtne kasutada. Puuduvad protsessorid ja muud peened osad, mille remont tavaliselt väga kallis (kui katki peaks minema). Väidetavalt väga vastupidav seade. Minukäes töötanud u. 2000 murevabat tundi.
TYPE TIG200P ACDC(WSE-200P)
Power voltage AC230V ±10% (single phase) , 50/60Hz
Rated input current 20A
Power capacitance 4.5KVA
Rated output current 185A
Range of output current 15~185A
Arc force 0-60A
No-load voltage 56V
Working voltage 17.4V
Pre-flow 0~2s
AC output frequency 60Hz
Clean width 20~80%
Slope-down time 0~10s
Post-flow time 0~10s
Base current 10~90%
Pulse frequency 0.5~300Hz
Pulse duty cycle 10~90%
Remote control Yes
Arc-leading HF vibration
Efficiency 85%
Duty cycle Imax (25'C) 60%
Duty cycle 100% (25'C) 150A
Power factor 0.93
Insulation class B
Protection class IP23
Welding thickness(AL,mm) 0.5~10
Machine Weight (kg) 20
Accessories Weight (kg) 5
Size (mm) 493*330*320
Hind: 450€
