M: Pihustid RC Engineering 750cc; Denso 550cc
Postitatud: 17.01.2013 14:09
RC Engineering SH4-0750, 6tk 400 €
Vähe kasutatud.
Flow Rate - CC's: 750 CC's / MIN @ 43.5 PSI
Resistance: 12.5 Ohms @ 68 F
Voltage: 8-15 Volts, nominal 13.5 Volts
Amperage: 1.0 Amps
Pressure: Min 30 PSIG / Max 70 PSIG
Denso 550CC, 6 tk 350 €
Kasutatud.
Flow Rate in CC per minute: 550CC/min @ 43.5 PSI or 3 BAR
Resistance: 12.5 ohms
Amperage: 1.0 Amps
Pressure: Min 30PSIG/ Max 100PSIG
Kontakt: 5260868; PS
Vähe kasutatud.
Amperage: 1.0 Amps
Kasutatud.
Amperage: 1.0 Amps
