M: Turbo Garrett T25 pärit saab 900 turbolt 96a.136kw MÜÜDUD
Postitatud: 27.12.2012 19:46
Müüa turbo Garrett T25 - 452083-0001, pärit saab 900 turbolt (136kw), töötab kenasti, hetkel veel autol küljes seega lõtkude kohta ei oska öelda.
NÜÜD TURBO MAHA VÕETUD!!! RISTILÕTK ON ÕHKÕRN JA PIKKILÕTK PUUDUB!!!
Infot Guuglist:
The T25 Turbo has an oil- and water-cooled bearing system. It is the smallest ball-bearing turbocharger produced by Garrett, which means it uses balls to separate the moving parts of a bearing. It has an internal wastegate, which is a valve that diverts exhaust gases away from the turbine wheel in the engine, and an inlet flange, which is essentially a strengthening rib or rim. This turbo is best for smaller engines with up to 270 horsepower.
hind 90€
56988644
Infot Guuglist:
hind 90€
56988644
