M: KMS management täisprogrameeritav aju
Postitatud: 23.02.2012 1:02
Postitas kulleer9
Pakkuda Kronenburg Management System KMS täisprogrameeritav juhtaju. Kuni 10 silindriga mootorite juhtmine!!
Pakkumine sisaldab:
KMS Juhtaju MA25(M)
aju pistikut ca.15 cm juhtmeid
Map andur
õhu temp. andurit
Trigger wheel-i
KMS ja arvuti vahelist juhet
KMS-i Tarkvara
+ lisaks veel wideband lamda displey
Hind: Kõik kokku ainult 725 € KIIRE
Tingi
kontakt ja lisa info: 53 44 18 19
Lühi info KSM juhtajust:
KMS management ECU MP25(M)/MA25(M)
Part nr.: 01-01-01-0001/0002/0003/0004
Capable yet affordable engine management system
The KMS MP25 ECU is a affordable and efficient engine management system. By using the minimum of sensors, three auxiliary outputs, one auxiliary input and a wide range of functions, the KMS MP25 ECU can cope with 90% of all types of Otto engines.
These basic functions make the MP25 a simple, reliable and effective engine management system at a very competitive price.
‘This is a engine management system designed by engine people to be used by engine people. Anyone who understands the mechanics of the Otto cycle, should be able to set up and use this system with little difficulty.’
Features:
Complete engine management system up to 10 cylinders
Self-learning lambda control in combination with KMS UEGO controllers
Engine diagnostics
Short cut protected outputs
Serial RS232 communication
External dashboard (NEW: KMS CAN display in combination with interface)
2 engine load sensors
Analogue input (2nd lambda, gearbox position, G-force sensor, EGT, etc.)
3 auxiliary outputs (Shiftlight, water-injection, cooling fan, etc.)
Pit lane limiter (variable)
RPM limiter
A.L.S. (variable)
Powershift (separate delay and cut-off time for each gear)
Boost control
Launch control (variable)
Idle control
Re: M: KMS management täisprogrameeritav aju
Postitatud: 12.03.2012 11:58
Postitas kulleer9
:arrow:
Postitatud: 13.03.2012 1:08
Postitas Autolab
Kas keegi seda eestis seadistada kah oskab?
Postitatud: 13.03.2012 10:56
Postitas hents99
Es-racing minuteada.
Postitatud: 16.03.2012 10:18
Postitas Laisu
http://www.es-racing.ee/?page=69" onclick="window.open(this.href);return false;
Postitatud: 01.04.2012 11:16
Postitas kulleer9
:arrow:
