Vaatasin just isegi, et tiritakse Vemsile järeleMotary1 kirjutas:MS3 on väljas
Mis on tore on see, et PCB jääb samaks nagu MS2hel nii et saab ka MS1hest MS3me teha.
The MS3 daughter card on its own will give you all these features and more:
* VE and ignition tables are now both 16 x 16
* 0.1% steps on VE table, 0.1 degree steps on ignition table
* Socket for an onboard SD card - no laptop required for data logging (SD Card not included)
* Built in USB port
* GM stepper IAC control
* Closed loop idle and mixture control
* CANBus communications for interface with GPIO Board, IO Extender, or other devices
* Staged injection
* Native support for many different OEM trigger patterns
The MS3 also gives you a starting point for even more expansion. You will be able to connect the pin headers on this board to additional hardware, such as the MS3X board (not yet released) or other cards to enable features like these:
* 8 channels sequential fuel control
* 8 channel sequential ignition control
* Individual fuel and spark trim for cylinder by cylinder tuning
* 2 and 3 channel PWM IAC control
* 2 stage nitrous controller
* Table switching for multi-fuel engines
* 2 step launch control
* And more!
