Tänane kuupäev 17.05.2024 23:31
 Teema pealkiri: M: Megasquirt 3x juhtaju
PostitusPostitatud: 30.11.2023 0:28
Müüa MS3x juhtaju.
Tegu on taastatud ja testitud juhtajuga. Juhtmestikku pole, aga annan kaasa pistikud koos kestadega. Ajus on 4bar MAP andur ning lisatud on lisa MAP andur baro korrektsiooniks. Kaasa saab ka bluetoothi adapteri.
MS3X Standard Features:
8 Sequential fuel injection outputs. Each can drive a high impedance injector, unused injection outputs can be re-purposed.
8 Logic level 5 volt ignition outputs. Works with many types of ignition modules and coils, including LSx coils and our IGN1A. Requires external module or coils with internal ignitors.
6 Medium current outputs. Use for 2 stage progressive nitrous, boost control, tach output, 3 wire idle speed control, general purpose PWM or relay control, or many other potential applications.
3 Analog inputs. Use for an external MAP sensor, second O2 sensor, fuel pressure, accelerometer, or general data logging.
4 Switch inputs. Can be used to start data logging, arm a nitrous system, switch tables, launch control, VSS input (Hall sensor or VR with external conditioner), and more.
1 Cam sensor input. Can be used with VR, Hall, or optical sensors.
VE and ignition tables are both 16 x 16 with full interpolation.
0.1% steps on VE table, 0.1 degree steps on ignition table
Socket for an onboard SD card – no laptop required for data logging (SD Card not included)
Built in USB port
GM stepper IAC control
Closed loop idle and mixture control
CANBus communications for interface with GPIO Board, IO Extender, or other devices
Staged injection
Native support for many different OEM trigger patterns
Emaplaadil olevasse pistikusse on ühendatud ka CAN (pin 3 ja 4).
Asub Tallinnas Mustamäel, eelistan käest kätte tehingut, aga saab ka postiga saata.
Kontakt: hendrik.tonsau[at]mail.ee , 527 969üks või privaatsõnum.
Hind: 500€
Kasutajad foorumit lugemas: Bing [Bot] ja 63 külalist
