https://www.eculabs.com/
SUPPORTED MODELS
Impreza GT Turbo (1999-2000)
P1, Type-R, Type-RA (1999-2000)
Impreza WRX and STI (1999-2019)
Forester Turbo (1998-2013)
Legacy Twin Turbo (1998-2003)
LIVE-TUNING & FAST REFLASH
Tune the maps while driving or on the dyno
Fast & reliable exclusive flash system
Down to 10 seconds reflash
Password protection & encryption
Work faster & efficiently
SMOOTH AND EASY TUNING
All OEM functions are available & tunable
Smooth cold & hot start
Restart after stalling
Warm up
Idle control
Low and high load driving
OEM A/F ratio closed-loop control
OEM emissions control
OEM knock control
OEM A/C control
OBD2 support (2001+ ECUs)
TUNE BEYOND LIMITS
Unlimited power and torque
Unlimited boost
Unlimited boost solenoid duty
Load limits removed
'Half-boost' conditions removed on pre-2001 ECUs
ADVANCED FUNCTIONS
Maps switching
FlexFuel with direct sensor connection
Big injectors tuning
Gear Based Boost Control
Any MAP sensor setup
CEL flashing on knock, overheating, FlexFuel sensor error
Wide-band O2 sensor connection on pre-2001 ECUs
Keys learning & immobilizer disable
Build any kind of setup
MOTORSPORT FUNCTIONS
Speed-Density
Anti-Lag System
Launch Control
Full Throttle Shifting
Downshifting Throttle Control
Sequential Gearbox control with Closed-Loop Cut
High value at a low price
249€* per ECU + shipping
OPTIONAL FEATURES
Multi-Map +50€*
FlexFuel +50€*
Speed-Density +50€*
Anti-Lag +50€*
LC/FTS/DTC +25€*
Shifting CL cut +50€*
Subaru originaalajude seadistamine.
