Lets make a offer for the weekend after a long time! Now we recommend to take advantage of this and get the Black Diamond brakes really cheaply in your shopping cart. The offer applies to all BD products, brake discs, pads, hoses and even brake fluid get -15% off.
Black Diamond has a great track record both on the streets and competition on both tarmac and dirt, they can also be used to replace the OEM brakes. Black Diamond brake discs are available in three model, grooved, drilled or with both. The Brake pads have a great grip and low dust level, they can also handle a big amount of heat. With discs and pads we recommend a braided brake hose kit, which is a great final update. Braided hoses make braking more accurate when the balloon-like effects are reduced from the brake pedal.
We recommend to use Black Diamonds brake fluid with brake parts so the brakes will run perfectly. Discount in Black Diamond is -15% at least, but we have also wide range of outlet BD parts with up to -40% off. Most common discs, pads, hoses and brake fluid can be found directly from our stock. We order more parts twice a week and even the most special discs arrive in less than a week.
Check the Black Diamond brakes from our webshop, prices includes discount (up to -40% off):
»» Black Diamond brake discs
»» Black Diamond brake pads
»» Black Diamond clutch hoses
»» Black Diamond brake hoses
»» Black Diamond DOT4 brake fluid
Have a great weekend!
-Riku
