Tänane kuupäev 19.04.2024 23:00
Tee uus teema Vasta teemale  [ 62 postitust ]  Mine lehele Eelmine  1, 2, 3, 4, 5
PostitusPostitatud: 25.08.2017 14:26
Weekie: Luisi steering wheels and hubs -10 %
Luisi's steering wheels and bolt-on hubs have earned their permanent place in our range.
Luisi has made steering wheels and hubs since 1965. There's a hub and wheel for every car!
You can find the basic model hubs in the webshop, and can get the airbag models (not street legal) from sales as they are much less sold. There's suede and pu wheels, and hundreds of bolt-on hubs at great prices, so check them out in the shop.
Steering wheel hubs have a double pcd which includes most common steering wheel brands (6x70 & 6x74mm).
For example: FK, JOM, Tuning Line, Sparco, Momo, OMP and naturally Luisi steering wheels will bolt straight on.
Check out the Luisi range from our webshop:
»» Luisi steering wheel hubs
»» Luisi steering wheels
Other things from this week
Brisk & NGK spark plugs for every purpose!
»» Brisk and NGK sparkplugs
D2 coilovers: value for money. The best coilover kit in the price range for every car.
»» D2 coilovers: Value for money
Cometic gaskets and arp bolts are the choice when building any engine.
»» Cometic & ARP
High quality turbosmart boost controllers and blow off valves work accurately in all circumstances.
»» Turbosmart bleeds and BOV
Have a great weekend!
-Riku
PostitusPostitatud: 08.09.2017 14:29
Weekly offer: OBP -10%
The UK-based OBP's handbrakes and pedalboxes offer optimum balance - and optimum braking. They are now celebrating their 10-year anniversary, so lets celebrate that with a -10 % off all OBP products.
OBP Hydraulic handbrakes
OBP handbrakes come in several flavors in either vertical, horizontal or an angled setup, with 280 or 600 mm handled, and for a twin or single line. Cyliners are standard size and exchangeable with most handbrake/pedalbox cylinders. This means the OBP cylinders we sell separately also fit most other handbrake and pedalbox brands.
Check out the handbrakes here.
»» Race.fi: OBP hydraulic handbrakes
OBP Pedalboxes
OBP pedalboxes are available as bolt-on (well, as bolt-on as a pedalbox can be), or universal setups for either floor- or firewall mounts. All kits can be ordered with or without cylinders, for different clutch setups and the optional bias quick adjustment which basically lets you turn the bias bar on the fly based on driving conditions. A pedalbox is the best solution as far as competition brakes go; they offer adjustability, direct feel to the brakes and remove dependency to engine vacuum.
»» Race.fi: OBP Pedalboxes
The most common handbrakes and pedalboxes are found directly from our stock, like most of our brake cylinders and line locks.
OBP supplies:
»» Race.fi: OBP line locks
»» Race.fi: OBP bias valves
»» Race.fi: OBP brake cylinders
Other news this week
Amsoil makes a high performance oils and additives!
»» Amsoil oils and additives
Eibach manufactures wide range of lowering springs, suspension kits and wheel spacers!
»» Suspension in shape with Eibach
K&N air filters will allow better fuel economy and more pure power!
»» K&N air filters
Quaife differential is one of the best updates for your car!
»» Quaife differentials
Have a nice weekend!
-Riku
This topic on our website
Kasutajad foorumit lugemas: Registreeritud kasutajaid pole ja 4 külalist
cron
