Tänane kuupäev 19.04.2024 17:12
 Teema pealkiri: FAST XFI 2.0 omadused
PostitusPostitatud: 24.10.2013 7:43
Uus juhtaju (toode on laokaup) FAST XFI 2.0 mida pakume, sisaldab endas:
Fast XFI 2.0™Intelligent Traction Control* – Internal Data Logging* ECU Includes
Main XFI 2.0™ ECU w/Intelligent Traction Control™ & Internal Data Logging
Wide Band NTK O2 Sensor w/ Wiring Harness
5 Ft. Communications Cable (25Ft. Available Seperately)
USB to Serial Converter Cable
XFI 2.0 uses a 104-pin wire harness versus a 60-pin on the original
Standard features
Built in wide-band O2
Full sequential and/or bank to bank capability
Speed density or Alpha N
Open/closed loop operation
High/low impedance injectors
Individual cylinder correction
Fan and fuel pump control
Up to 16 injector control
1,2,3 and 5 bar MAP capability
Diagnostic lights
Power adder features
IAC control
External data logging (requires laptop)
Multiple calibration files available via toggle switch (no laptop)
And much more…
New features include
Self Learning Auto Tune VE Table
User Adjustable Battery Voltage Injector Opening Correction Table
Fixed Timing “TEST” Mode: easy verification of ignition timing accuracy
Spark vs. Coolant Temp Offset Table
User Configurable Target Air Fuel Offset Table vs. Coolant Temp Table: more accurate warm-up enrichment
User Selectable Safety Feature: deactivates all power adder features in event of fault code
Automatic & Manual TPS Calibration Modes
Additional Transbrake Control Features
Improved On-Board Diagnostics
Advanced Forced Induction, Power Adder & Race Controls
Optional Features:
Transmission control
Coil over plug, DIS ignition control
Internal data logging
Traction control
Hardware
The XFI 2.0™ uses the latest in flash microprocessor technology to deliver a significant increase in processing speed. This means the XFI™ can process, analyze and adjust four times faster than previous EFI systems. In addition, a surface mount component circuit board and billet ECU enclosure give the XFI™ superior durability. And to simplify installation, FAST™ offers engine-specific XFI 2.0™ Wiring Harnesses featuring clearly labeled connections.
Software Advances
The C-Com XFI™ Windows-based software is easy to navigate and incorporates several previously unavailable features, such as field flashable capabilities that enable you to download the latest software updates via email or directly from the FAST™ website. Stay current without ever removing the XFI 2.0™ from your vehicle.
Technology
The XFI 2.0™ features Qwik Tune™ Technology, which allows ECU programming without a laptop. Preprogram up to four different EFI MAPs, and select the tune-up you need with the flick of an in-car switch. Optimize one setting for everyday driving, others for racing conditions and still another for improved fuel economy. Other features include on-board diagnostics, EZ Test™ Indicator Lights, five bar MAP sensing and controls for your power adder and torque converter. The XFI 2.0™ also offers enhanced data logging capabilities and memory for analyzing up to 8 additional monitored inputs.
Rohkem infot: http://premiumparts.ee/work/fast-xfi-juhtajud
Tutvustav videoklipp : FAST XFI juhtaju
Premium Performance OÜ
Performance & race osad ning varustus USAst
Projektiautode ehitus ja USA autode hooldus
Projektimootorite ehitus ja käigukastide remont
TIG keevitus
 Teema pealkiri: Re: FAST XFI 2.0 omadused
PostitusPostitatud: 24.10.2013 9:52
Äkki lisad ka mingid hinnad juurde, oleks informatiivsem.
IvarR
Võistlusautode ehitus.
PostitusPostitatud: 24.10.2013 11:20
Fast XFI 2.0 komplekt koos sisemise data logimisega : 1450 Eur+KM
TIG keevitus
Kasutajad foorumit lugemas: Registreeritud kasutajaid pole ja 5 külalist
cron
