TurboClub
http://foorum.turboclub.ee/
HALTECH omadused
http://foorum.turboclub.ee/viewtopic.php?f=15&t=10930
Autor:  RICE BURNER [ 18.09.2012 11:22 ]
Teema pealkiri:  HALTECH omadused
Panen siia Haltech PS2000 juhtaju kirjelduse
High Performance Fuel and Ignition ECU
With 14 channels capable of controlling injection and ignition duties, the Platinum Sport 2000 can support most modern engines (including 3 rotor engines) with multi-coil or conventional distributor ignition systems as well as aftermarket CDI systems.
It is capable of controlling sequential injection on 4,6,8,10 & 12 cylinder engines and direct fire ignition for engines up to 6 cylinders, or wasted spark ignition on engines up to 8 cylinders.
Features:
•11 additional user-definable auxillary inputs
•Up to 13 additional user-definable auxillary outputs (Depending on configuration)
•Fully user-definable 32 x 32 mapping ( Up to 1024 points)
•Wideband “Auto tuning” using user definable target AFR table
•Narrow and Wideband closed loop O2 control
•Staged injection control for multiple injectors per cylinder (inc rotary)
•3D mapped rotary engine ignition split
•Soft and hard cut rev limiter
•EGT fuel correction
•Tuning via TPS with manifold pressure correction
•Dual map switching for fuel/ign/boost
• Anti-lag (Rally and Launch style)
•Rotational idle
•Launch Control
•VTEC cam timing control
•VANOS cam control (intake cam only)
•True variable cam control supporting late model Toyota’s, WRX’s and EVO’s
•Dual intake runner control
•Onboard 2.5 BAR MAP sensor (or use with external MAP up to 10 BAR)
•Custom sensor calibration (Use your own sensors for temps or fuel/oil pressure etc)
•Open or closed loop boost control ( Road speed, RPM or gear based mapping)
•Closed loop idle control (Stepper motor and BAC type)
•Extra injector control
•Thermo-fan control ( Duty cycle or on/off )
•Intercooler fan/spray
•Alternator control (Mazda)
•Engine control relay function
•Nitrous switching with fuel / ignition correction
•Staged shift lights
•Aux fuel pump control
•Tacho output (5v,8v,12v)
•Turbo timer
•Torque converter lock up
•Air con request idle up
•Windows 2000, XP, Vista compatible software
•”In the field” updatable Firmware provides all the new features as soon as they are available
•Onboard and laptop data logging with Data Viewer software
•USB communication with laptop/PC
•CAN Bus port for direct plug in communication with Racepak and Aim Dash system.
Typical Applications:
•Control of fuel injection on modified engines
•Conversion from carburetion to fuel injection
•Race and rally applications of all description
•Design and development purposes
•Educational use by universities and technical colleges
•Original equipment in cars and motorcycle
http://www.haltech.com/
Lisainfot saab meili teel
viljar@vkmmotors.ee
Autor:  RICE BURNER [ 08.10.2012 18:32 ]
Teema pealkiri:  Re: HALTECH omadused
See on huvitav toode, millest oli turul kindlasti puudus ;)
Autor:  RICE BURNER [ 25.11.2012 14:15 ]
http://vkmmotors.ee/upload/editor/files ... ri_VKM.pdf
Kõik juhtaju tüübid laos katsuda ja vaadata !
Lisainfo telefonil
5037337
Autor:  VKM_Motors [ 23.02.2016 14:44 ]
Elite 750
01.03.16 müügile saabuv juhtplokk. Sobib ideaalselt kuni 8 silindrilistele hobiautodele ja tänavasõidu autodele.
Hind koos juhtmestikuga (ilma kaitsmekarbita):1670€
Hind ilma juhtmestikuta: 1425€
Lisainfo ja tellimine Shop@vkmmotors.ee
Omadused:
• Waterproof Case (IP67)
• 34 Position AMP connector
• 6 x Fuel Injection Outputs
• 6 x Ignition Outputs
• 5 x Digital Outputs
• 5 x Analogue Voltage Inputs
• 2 x Digital Pulsed Inputs
• USB Laptop Communications up to 1 MB/s
• 2 x Engine Position Inputs with extensive trigger type support
• ESP Calibration Software – Intuitive and easy to use
• CAN Bus communication for Haltech CAN Expansion
• User definable tables
• Multi-fuel Support – Support for Petrol (Gasoline), LPG, Methanol and Ethanol
• E85 Flex Fuel Ready – Direct connection to sensor
• Closed Loop 02 Control
• On-board Data Logging
• ECU comes fully enabled, no additional charges for advanced features
• 1 to 8 Cylinder engines or 1 to 3 rotor engines
• Normally aspirated or forced induction
• Load sensing by Throttle Position (TPS), Manifold Absolute Pressure (MAP) or Mass Air Flow (MAF)
• In-built 29PSI MAP Sensor
• Sequential, semi sequential, batch or multipoint injection patterns
• Distributor ignition systems, multi-coil systems or Haltech Multiplex CDI systems
Sisendid, Väljundid:
Fuel Injectors: 6 x Peak & Hold injector drivers
Ignition: 6 x Over current protected ignition drivers
Analogue Voltage Inputs : 5 x Analogue Voltage Inputs
Synchronised Pulsed Inputs: 2
Digital Pulsed Outputs : 5 x over-current protected low side pulsed outputs
Internal MAP Sensor : 3 Bar internal MAP sensor
Supports up to 200Kpa of boost (2Bar/29psi)
Tehnilised andmed:
Input Supply Voltage : 8VDC to 16VDC
Output Sensor Supply Maximum Current Ratings:
5V Supply: 100mAMax
Mõõdud:
Dimensions: 127mm (L) X 127mm (W) X 39mm(H)
5.0″ (L) X 5.0″ (W) X 1.54″ (H)
Weight: 350g (0.771lb)
Autor:  VKM_Motors [ 23.02.2016 14:56 ]
Elite 1500
Haltech Elite Series ECUs take the art of engine management to a brand new level. With a waterproof case, drive-by-wire, exhaust cam and knock control the Elite Series ECUs provide cutting edge technology to tuners and performance enthusiasts world-wide.
Hind koos pika juhmestikuga ja kaitsmekarbiga:2020€
Hind ilma juhtmestikuta:1730€
Omadused:
• 4 x Fuel Injection Outputs
• 4 x Ignition Outputs
• 20 x Digital Outputs
• 10 x Analogue Voltage Inputs
• Drive By Wire (DBW) Throttle Control
• 6 x Engine Position Inputs with extensive trigger type support
• Programmable Injector Peak and Hold Currents
• OBDII Capable – Set and clear diagnostic trouble codes, view live engine data
• Dual CAN Bus communication for OEM and Haltech CAN Expansion
• User definable 5D Tuning – Tune by gear, Cam angle or any channel for ultimate flexibility
• Variable cam control – Independently control up to 4 camshafts
• Auto tune capabilities – Short and Long term fuel, ignition, boost and idle control learning
• Staged Fuelling – Up to four stages of injectors
• Single Channel Knock Control – with high speed digital filtering for accurate detection
• E85 Flex Fuel Ready – With additional boost tables
• Closed Loop Boost Control – Multiple Modes – Tune by gear, wheel speed or time
• Closed Loop Idle Control – With learning for consistent idle stability
• Closed Loop 02 Control – Dual bank control for precise tuning
• Anti-Lag and Launch Control – Drag and Rally modes
• Data logging – Internal memory & external laptop logging
• Multi Level Engine Protection – Set limits for sensors and protect your engine
PiltPilt
Autor:  VKM_Motors [ 23.02.2016 15:17 ]
Elite 2500
Kõige suuremate väljundite ja sisenditega juhtplokk. Võimalik juhtida kõikvõimalike mugavusseadmeid lisaks mootorile, näiteks nagu Kliimasüsteem, ABS, püsikiiruse hoidja jne.
Hind koos pika juhtmestikuga ja kaitsmekarbiga:2520€
Hind ilma juhtmestikuta:2250€
Omadused
• 8 x Fuel Injection Outputs
• 8 x Ignition Outputs
• 28 x Digital Outputs
• USB laptop communications
• OBDII Capable – set and clear diagnostics trouble codes
• New “ESP” calibration software – More intuitive and easier to use than ever
• Dual CAN Bus communications for OEM and Haltech CAN expansion
• User definable 5D Tuning – Tune by Gear, Cam Angle or any channel for ultimate tuning flexibility
• Variable Cam Control – Independently Control up to 4 camshafts
• Dual Channel Knock Control – With FFT analysis for accurate detection
• Auto Tune Capabilities – Short and Long term fuel, ignition & boost learning
• Multi-fuel Support- Support for Petrol (Gasoline), Methanol and Ethanol
PiltPilt
Autor:  VKM_Motors [ 01.02.2017 18:31 ]
Haltech Elite 2500T with ATM (Advanced Torque Management)
Lühidalt tegemist siis Haltechi uue tootega, mis kontrollib ratta pöörlemiskiirust.
https://www.youtube.com/watch?v=9LPTR9nMl1o
Toode on saadaval järgmiste variatsioonidena.
Haltech Advanced Torque Management on saadaval järgmiste toodetena:
• Elite 2500T
• Elite 2500 (Elite 2500 uuendatakse 2500T peale)
• REM (Race Expansion Module)
Omadused:
Elite 2500T (DBW + Advanced Torque Management)
Applications:
• 1 to 12 cylinder engines
• 1 to 4 rotor engines
Features:
• Torque Management Functionality
• Variable cam control – Independently control up to 4 camshafts Auto tune capabilities –
• Short and Long term fuel, ignition, boost and idle control learning
• Dual Channel Knock Control – with high speed digital filtering for accurate detection
• Multi-fuel Support – Support for Petrol (Gasoline),LPG, Methanol and Ethanol
• E85 Flex Fuel Ready – Direct connection to sensor.
• Data logging – Up to 40 channels of logging. Sampling rates up to 5ms
Outputs:
• 8 x Current controlled injector drivers
• High or Low impedance injector compatible
• Programable Peak Current – 0A – 8A
• Programable Hold Current – 0A – 2A
• All spare injector outputs can be used as generic DPO’s with 1A Max output.
• 8 x Over current protected ignition drivers
• All spare ignition outputs can be used as generic DPO’s with 1A Max output.
• 5 x Over current protected low side pulsed outputs
• 1 x Dedicated engine control relay output which can control up to 6 relays simultaneously
• 2 x Over current protected hi / low side motor outputs
• Suits most OEM throttle bodies and pedals
• 1 x 4 wire stepper motor control
• Can be configured as 4 x hi / low side outputs
Inputs:
• Supports variable reluctor and digital inputs
• 3 Bar Internal MAP Sensor rated up to 200kPa of Boost (2bar/29psi)
• 2 x CAN Bus communication for Haltech CAN and Vehicle CAN Expansion
• 1 x USB Connection for Programming
• Fastest Sample Rate 5ms
• 2MB Internal Storage
Hinnad:
• Elite 2500T 3999€ koos KM.
• Elite 2500 (Elite 2500 uuendatakse 2500T peale) 1860€ koos KM.
• REM (Race Expansion Module) 2900€ koos KM.
Lisainfo ja tellimine shop@vkmmotors.ee
http://www.phpbb.com/
