Tänane kuupäev 18.04.2024 17:47
PostitusPostitatud: 01.12.2019 20:50
Müüa sepiskepsud VAG 1.8T 20v mootorile. Kaasas ARP 2000 poldid. Ideaalses korras.
Asuvad Tartus. 56921046 või kiri PS.
Hind 180.-
Center to center length: 144mm
Big end diameter: 50.6mm
Small end diameter: 20mm
Big end width: 24.9mm
Small end width: 24.9mm
Type: Forged 4340 aircraft chrome moly quality steel for racing
H-beam Conrods Quantity: 4 Pieces a set
Bolts: Including Genuine ARP 2000 bolts
Bolts Size: ARP 2000 3/8" bolts
Tolerance: Balanced to +/- 1 gram in set
Piston Bolt Hole: +-4/1000mm
Power: 600hp ~ 800PS per set
Strength of the fastening (PSI): 220,000/230,000 PSI Torque: 48ft ≈ 65 NM
Top acceleration: 9000rpm
Viimati muutis David, 07.12.2019 18:04, muudetud 1 kord kokku.
PostitusPostitatud: 06.12.2019 9:59
Up!
Kasutajad foorumit lugemas: Bing [Bot], Google [Bot] ja 28 külalist
