Väga hea tööriist logimiseks ja sõidu analüüsimiseks. Ostetud lisa litsents millega saab sünkida gopro videosid (näidikud jne videole juurde)
Custom LCD panel dashboard display, clearly visible under any light condition, specification
Water resistant for open top or motorcycle applications
Compact and slim, easy to fit. Click here for a dimensioned drawing
Suitable for any engine installation with a fully configurable RPM scale
Optimise your gear changes with the configurable ultra bright shift lights
Road legal, everything required for an MOT or SVA testing including tamper proof odometer, backlit display and mandatory warning lights.
Lap and sector time display using a separate data logger
Easy integration with other Race Technology products
Stand alone operation. Connect up to 4 engine or gearbox sensors as well as RPM and wheel speed.
Display information directly from your ECU using our CAN or serial interface*
Monitor your engine and display high/low alarms for any parameter.
Gear position indicator. Calculated or using a gearbox sensor
User selectable units MPH/miles or KPH/km
Display the information you want to see with 5 user defined screens
Control the DASH2 and a data logger with the external button set (optional)
Easy to use configuration software, available free here
Package deals available
Fitting service available
Powerful onboard processing - perform calculations live. The results can be viewed live (on a display or recorded to video using a VIDEO4), not just in post analysis:
Timeslip can be calculated live and displayed directly to the driver, showing exactly how much faster or slower you are continuously - not just at lap and sector markers.
Sensor data is processed directly by the unit rather than having to be processed in the dashboard, VIDEO4 unit and Analysis software separately.
User defined channels used to perform maths functions on the live data, e.g. combine 4 wheel speed sensors to show if the average speed of the front wheels is higher than the rear wheels, showing spin and braking lockup. This can be displayed live to the driver, overlaid onto a video, or logged for analysis.
Review your braking points and grip usage with the built in 2g 3-axis accelerometer (optional 6g enhancement available for high downforce applications).
Capable of detecting minute changes with 100Hz update rate on all sensor and accelerometer channels.
Lap and sector timing, in the software, or live with a DASH2 or DASH4 PRO display.
Unrivalled accuracy with our 20Hz GPS option (5Hz standard).
Measure your drift angle with the gyro option.
Extensive automatic logging control, making sure exactly the required data is logged.
Get the most out of your engine by logging information from your ECU* or vehicle's CAN data stream**.
Optional GoPro control + video licence, for synchronised HD video and DL1 data.
1000 eur komplekt
